Stuck bolts
06 May 2014 18:38 - 06 May 2014 18:43 #114322 by Casey
Stuck bolts was created by Casey
Having ordered the replacement kingpin bearings I decided to bite the bullet this weekend and started on the front passenger side. Problem was when I got to the part of the guide that said 'remove the bolts holding the disc backing plate (and the hub) to the knuckle joint' it turned out the bolts wouldn't budge, even after a healthy dose of WD40, mainly because someone had been there before and slightly rounded the heads and a ring spanner wouldn't fit.
Oh and mine isn't the same as the photo in the guide (see below), as mines got a cog wheel at the back of the hub that reduces the gap to about a spanners width.
Has anyone got any idea how I can remove them and where I can get replacements?
Last edit: 06 May 2014 18:43 by Casey.
  • steffan
06 May 2014 18:59 #114326 by steffan
Replied by steffan on topic Stuck bolts
Put it all back together and start over from scratch now remove the wheel undo and remove the steering bars remove the caliper and cable tie out of the way now take off the auto / manual hub and remove the cer clip on the drive shaft now undo all the 10mm bolts on the back of the swivel seal and undo the king pin bolts and remove king pins now the hole hub should come off as one lump replace kingpings and axle oil seal for the hell of it you may aswel as your in there anyway and repeat all actions in reverse job done in under 30 mins thank you please call again ;)
06 May 2014 20:11 #114330 by Casey
Replied by Casey on topic Stuck bolts
Thanks for the advice.
Are these the 10mm bolts you mean? If so they're looking in even worse shape than the four I couldn't get out, in fact they look completely round.
I'll have a closer look.
  • Yellostreak
06 May 2014 21:03 #114335 by Yellostreak
Replied by Yellostreak on topic Stuck bolts
probably just covered in Cr*p. use a good 6 sided socket on them and take your time..
06 May 2014 21:22 #114336 by Casey
Cheers, I'll give it a go.
  • Wiltec17
06 May 2014 21:27 #114337 by Wiltec17
Replied by Wiltec17 on topic Stuck bolts
www.ebay.co.uk/itm/laser-3925-Alldrive-B...&hash=item416aced6ea
Obviously a last resort but very effective at removing rounded or damaged bolts. It would meen replacement of the bolt but worth considering if they do round. I keep a set in my toolbox at work, I use them for removing locking wheel bolts.
Time to create page: 0.154 seconds
