Dust Problem
12 years 6 months ago #114366
by Obarno
Replied by Obarno on topic Dust Problem
The point I was making was fit a pollen filter!
- Childs
12 years 5 months ago #117971
by Childs
Replied by Childs on topic Dust Problem
nHi Guys
Sorry taken so long to get back, I have tried all the following, one thing at a time to see if they make any difference.
New Pollen Filter
Cleaned around the vent behind the rear bumper on nearside
Temporarily filled a hole that needs welding where the jack is stored.
All have made no difference as we are still getting dust inside, out for two hours across Salisbury Plain yesterday on scalping tracks and all interior has a good layer of dust on it. As I have said earlier this didnt happen before so something must have changed.
Any help appreciated.
Thanks
New Pollen Filter
Thanks
12 years 5 months ago #117996
Replied by helijohn on topic Dust Problem
Just a guess as the sensible suggestions have been covered but what about the gear lever seal?
- Childs
12 years 4 months ago #119253
by Childs
Hi Guys
Have been checking around the rear door and found that there is a lot of play in the bottom hinge. I can lift the outside edge of rear door when open and hinge/pin moves a lot. Do you think this would not give a good seal on the door when off road and allow the dust in through there? If so will it be only the pin that is worn or both pin and hinge will need replacing?
Thanks.
Thanks.
Time to create page: 0.084 seconds
