Which exhaust part do I need?
  • minibbb
03 May 2014 15:28 #114023 by minibbb
Which exhaust part do I need? was created by minibbb
My 2005 JLX got an exhaust blow which the garage informed me was just in front of the cat. I was hoping to have this welded but now the exhaust is making a horrible rattling noise once its warm. On looking underneath I can't actually see any damage mind you.
I think its the section attached to the manifold but before the cat that's at fault.
In the pic I think its the pipe on the left at fault.
Do I need the full cat assembly like this?
This part is about £100 on eBay but I wouldn't be able to fit it myself. Is it best to buy the part and get a garage to fit it or use an exhaust place like quik fit etc to supply and fit the part?
Many thanks :)
03 May 2014 15:54 #114026 by facade
I cant actually see anything wrong with yours :dry:
The usual source of the most terrible rattle, that has dogs howling, cows going dry, chickens sucking the eggs back in and everyone in the street staring and pointing, is the silver cover on the catalyst, with the perforated holes in- it comes loose, looks like yours already has on one side and been fixed back on with bolts, likely the other side is off now.
If the hole is in that pipe and not bodgeable, yes you do need the whole thing. Get a price at Kwick-fit if you dare :woohoo: they won't supply a £100 part, and get a price for fitting one you supply at your friendly garage, likely about £45.
The following user(s) said Thank You: minibbb
  • ne-crock
03 May 2014 16:30 #114027 by ne-crock
Replied by ne-crock on topic Which exhaust part do I need?
my exhaust split between the downpipe and cat (i think thats where your on about) about a year ago, i had it welded up and it was fine, its just a compression fitting and i presume over the heat cycles it gets loose and eventually spits apart, quick bit of welding and good as new,
as facade says the rattlings probably the heatsheild,
  • gilburton
03 May 2014 17:29 #114036 by gilburton
Replied by gilburton on topic Which exhaust part do I need?
I had my cat replaced at a Wilco/Fastfit and to be honest the cost was much the same as ebay so why struggle with rusted bolts??
  • minibbb
03 May 2014 18:27 #114038 by minibbb
Replied by minibbb on topic Re:Which exhaust part do I need?
Thanks for the replies guys :) I can't see any damage to the heat shield but its v loud rattling! It looks like this from the other side
I have noticed though that this part looks like it could rattle, not sure it would make such a racket though!
I think I'll take it to the garage and ask them to have a proper look at it on the ramp to see if its saveable or whether I'll need to fork out for a new one! Might ask the local exhaust places for a quote just to see if they're compatible to sourcing the parts myself
  • markyp2000
03 May 2014 19:23 #114041 by markyp2000
Replied by markyp2000 on topic Re:Which exhaust part do I need?
Give it a thump and find where its rattling
Time to create page: 0.522 seconds
