Death wobble?
- rexthecat
12 years 6 months ago #113841
by rexthecat
Death wobble? was created by rexthecat
Spent ages getting back on the road but got a new problem! Front wheels seem to start wobbling like the tracking is out, between 25 and 40 mph, comes and goes. Thought it was a tie rod end as I knew that needed doing, but got a new one on and tracking done, if anything it's worse. Does that sound like 'death wobble' thought it was normally more like 45?
Will have a check of the wheel bearings at the weekend, wanted to go off road sun, if it is death wobble do folks put up with it? I guess i mean can i still use the car till i track it down?
Ta
Ta
12 years 6 months ago #113859
by kirkynut
Replied by kirkynut on topic Death wobble?
I found that if you had multiple components with wear but not excessive wear, the more things you replace the more one worn component that's left makes the wobble feel bad, until you locate that and deal with it.
If it's not to the point where it shakes the car violently then it can be put up with.
If you have extreme MT pattern tyres, expect to live with a little.
- jonesyba420
12 years 6 months ago #113861
by jonesyba420
Replied by jonesyba420 on topic Death wobble?
as kirky said unless its shaking the car so violently to the point of the car being hard to control put up with it and keep replacing any worn out components.
ive always had slight wobble......................i just deal with it as its only at a certain speed (between 40-50mph)
- Wiltec17
12 years 6 months ago #113889
by Wiltec17
Replied by Wiltec17 on topic Death wobble?
The wobble from mine was evident long before there was any play detectable in the wheel. Was a slight wobble and only really noticeable if you let go of the wheel. I'd say it started around 35mph and was fine again after 45mph.
Is it just noticeable through the steering wheel or is the vehicle shaking?
I put up with mine for a while but it isn't a massive task to do and I was suprised just how bad a state they were in when I got it apart. Well worth stripping down and doing, whilst your In there, clean and regrease, my cv was dry and there was only a tiny amount of grease left in the hub
12 years 6 months ago #113967
by kirkynut
Make sure nothing is really worn to the point of being dangerous though when working through each component at s time. Fix the worse condition ones first, then move on to the ones you can't see wear but it may be there, like bushes.
- rexthecat
12 years 6 months ago #114156
by rexthecat
Replied by rexthecat on topic Death wobble?
Can't find much signs of wear, bushes are new, comes and goes, think I'm going to put a damper on for the mo and shims on the kingpins.
Cheers for the help
Cheers for the help
Time to create page: 0.089 seconds
