Air Conditioning Question
30 Apr 2014 23:04 #113838 by Busta
Replied by Busta on topic Air Conditioning Question
What do you mean by 'advanced' air conditioning? If you mean climate control (where you choose a temperature and the system aims to maintain it) it has never been an option and I doubt it ever will.
On current models, the SZ3 doesn't have air conditioning. The SZ4 does.
This information is easily found on the Suzuki website.
  • hunter1084
01 May 2014 04:51 #113846 by hunter1084
Replied by hunter1084 on topic Air Conditioning Question
I have a 2013 model and it has the best airconditioning than any other car I've been in, changes from cold to hot near instantly
  • jonathan
03 May 2014 16:43 #114030 by jonathan
Replied by jonathan on topic Air Conditioning Question
my 2012 SZ4 has air con and it works great , the heater is good to ,, i am thinking of putting the heated seat kit in it as fitted to the JB43 Sierra model in Japan ,,, note if the pollen fitter is blocked or dirty the air flow is reduced and should be changed once a year
03 May 2014 17:28 - 03 May 2014 17:29 #114035 by facade
Replied by facade on topic Air Conditioning Question
The Other Car has climate control - USELESS!
When I'm hot I want icy cold air in vast amounts, especially on my poor hot & sweaty feet.
The previous Other Car simply had a button for chiller on, and you cranked the hot up & down to regulate the temperature of what came out the vents, and twizzled knobs to make it blow more or less and up or down.- perfect B)
I run The Current Other Car as close to manual as it will go, I set where the air comes out and how fast the fan goes, but the only way to get cold air is to crank it onto 16 degrees all the time, and then it isn't particularly cold.
No doubt the "climate control" cost extra over "air con" too ..........
Last edit: 03 May 2014 17:29 by facade.
  • helijohn
03 May 2014 20:41 #114049 by helijohn
Replied by helijohn on topic Air Conditioning Question
markyp2000 wrote: Mines a 99 and has factory air con mmmmm works lovely
Me too and it is one of the best I've had apart from Jeep. I have climate control on my Paj but I override it with my own settings.
Time to create page: 0.098 seconds
