Tie rod end help
  • The Dug
12 years 6 months ago #113601 by The Dug
Tie rod end help was created by The Dug
Evening folks,
Started my king pin bearing replacement today and it's turned into a bit of a disaster.
Due to my wee swim in salt water a few weeks back a lot of the bolts have crumbled (rear brake calliper bolt and all four of the backing plate) so I've had to chisel them off, this has left me with a drill and tap job.
However, main problem at the moment is the tie rod end top nut is spinning and I can't get it off, I've tried jacking it up, clamping it with joint splitters and different mole grips but no joy - can anyone suggest another approach? Last resort will be cut it off and replace the end but I really want to avoid that if I can.
Cheers
  • Yellostreak
12 years 6 months ago #113604 by Yellostreak
Replied by Yellostreak on topic Tie rod end help
probably be cheaper and quicker to get a tie rod end.. if its the one going through the hole on the hub then reality is that its usually corroded to hell anyway.. mine was a bugger to get off but I have the benefit of an impact gun
  • GuardianAngel
12 years 6 months ago #113631 by GuardianAngel
Replied by GuardianAngel on topic Tie rod end help
You have tried all things I would have done. GRINDER TIME :-D
  • markyp2000
12 years 6 months ago #113633 by markyp2000
Replied by markyp2000 on topic Tie rod end help
You could try a nut splitter
or hacksaw down one side as close to the tread as possable then undo it and get a new lock nut
  • GuardianAngel
12 years 6 months ago #113717 by GuardianAngel
markyp2000 wrote: You could try a nut splitter
Don't use the Laser ones. Crap things. The locking grub screw that stops the splitter from rotating always snaps. Also the machining of the thread that the splitter screws into is rubbish, keep getting stuck.
12 years 6 months ago #113737 by facade
Replied by facade on topic Tie rod end help
All 3 of mine did that: I just split the nuts and got new ones- they are fine thread same size as the wheelnuts M12x1.25 IIRR.
Can't remember how I split them, could have hacksawed a slice out, could have used a nut splitter, most likely the nutsplitter, I usually try that first.
Time to create page: 0.095 seconds
