VVT Engine Exhaust Replacement Advice Please
12 years 6 months ago #113579
by bryn
VVT Engine Exhaust Replacement Advice Please was created by bryn
I am about to replace the 3 sections of the exhaust on my 2007 Jimny and before I commit to buying off ebay I have a few questions.
1, Will a 2001 exhaust onwards (catalytic converter under floor section) fit my Jimny or did this part of the exhaust change when the engine was up graded. I ask because a supplier on ebay (CLICKCARPARTS) says the catalytic converter front section will fit from 2001 to present.
2, Can a VVT Jimny owner who has replaced their exhaust in particular the cat section give me the name of the company the used on ebay please,
Thanks for looking and your help.
bryn
bryn
12 years 6 months ago #113590
by j999pre
Grey pick up Jimny
Replied by j999pre on topic VVT Engine Exhaust Replacement Advice Please
I put one from a 2001 m13a on a 2005 vvt. Fitted no bother. I believe the other parts are different? Maybe hanger locations?
Grey pick up Jimny
12 years 6 months ago #113715
by bryn
Replied by bryn on topic VVT Engine Exhaust Replacement Advice Please
I'm beginning to think that as long as the cat part of the exhaust was made after 2001 then it will fit. It seems that the middle and back box are different when it comes to the VVT engine but the front cat remains the same. (2001 onwards).
bryn
bryn
- gilburton
12 years 6 months ago - 12 years 6 months ago #114178
by gilburton
Replied by gilburton on topic VVT Engine Exhaust Replacement Advice Please
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThey changed the way the rear box connected to the middle pipe.
Basically the earlier ones had the bend in to the box flange on the middle section.
The later ones had this bend on the silencer box so as long as you fit the whole thing it should match.
If you want the correct ones you have to fit/buy VVT 2005 on.
note the bend/flange
Can't guarantee the fittings will fit though??
Last edit: 12 years 6 months ago by gilburton.
Time to create page: 0.080 seconds
