Engine change how long
- Charlie b
12 years 6 months ago #113000
by Charlie b
Engine change how long was created by Charlie b
Hi chaps
I bought a jimny with a engine problem the cam had chewed up the cam carriers !!!
Wot causes this?
Some of you said just get another head easyer said than done!
I've bought a complete engine now
How long should it take me to do a comets swap
I have all tools
And a set of car ramps!!!!
Wot causes this?
I have all tools
- idiotmobil
12 years 6 months ago #113001
by idiotmobil
Replied by idiotmobil on topic Engine change how long
depend on how good you are should on average take a nice weekend, should get it out and back in easerly in a day then spend the next morning or day finishing off and servicing it
- Dave cc
12 years 6 months ago #113010
by Dave cc
Replied by Dave cc on topic Engine change how long
Easy as hell that change mate should have no problem doing in a day just beware about the clutch if worn change it while the engine is out coz its a shite job doing it at a later date under the car due to Suzuki not making the crossmember removable
12 years 6 months ago #113037
by facade
Lack of lubrication to the cam
Most likely not changing the oil/filter regularly blocks the tiny feed to the cam.
Could have been oil contamination/wrong grade/not enough oil.
Is the replacement engine out of the same year Jimny? There was a difference in cam sensor pickups between years.
Replied by facade on topic Engine change how long
Charlie b wrote: Hi chaps
Wot causes this?
Time to create page: 0.084 seconds
