Problem
  • Bullfrog
12 years 7 months ago #112413 by Bullfrog
Problem was created by Bullfrog
Hi everyone and good morning. I wonder if anyone would like to offer opinions regarding a problem with a 1999 Jimney please? The car belongs to my wife and has developed an intermittent problem whilst driving on long straight runs at 50 mph or over. After a while, the slightest movement of the accelerator causes alarming clunking from the rear of the car and it seems like something is disengaging and re-engaging ferociously. Could this be a problem either with the differential or with the overdrive? The engine itself is still running smoothly and there is no overheating. Eventually it goes away and it never happens when driving around town. Any opinions as to the possible cause of this issue would be very helpful. Thank you for your time.
  • markyp2000
12 years 7 months ago #112416 by markyp2000
Replied by markyp2000 on topic Problem
Could be gear box mount transfer mounts rear trailing arm bushes
  • Shima
12 years 7 months ago #112417 by Shima
Replied by Shima on topic Problem
Exhaust bush? Sounds stupid but i did the same thing. Worried that my diff was broken then realized it was the exhaust banging. I felt special that day.
12 years 7 months ago #112443 by Rhinoman
Replied by Rhinoman on topic Problem
Worn axle/trailing mount brackets? bad diff, its a fairly long list you just need to get underneath it and check it all out.
The following user(s) said Thank You: Bullfrog
  • idiotmobil
12 years 7 months ago - 12 years 7 months ago #112444 by idiotmobil
Replied by idiotmobil on topic Problem
Shima wrote: Exhaust bush? Sounds stupid but i did the same thing. Worried that my diff was broken then realized it was the exhaust banging. I felt special that day.
don't worry I done the same sort of thing was looking for a f*&ked mount/bush for ages and wile looking didn't even think of wobbling the exhaust used to do it wile bumpy offroading
Last edit: 12 years 7 months ago by idiotmobil.
