Drivetrain screeming noise. Vvt
- macguyverjimny
16 Apr 2014 22:40 #112384
by macguyverjimny
Drivetrain screeming noise. Vvt was created by macguyverjimny
Hi guys,
I would like some personal opinions,
I have a screaming noise on my drive train it can be heard at 3000-4000 rpm in 3rd gear and in 4 th gear,
When im at 80kph in 4 th gear then i can hear a screeming sound and as soon as i change to fifth gear the noise is totally gone.
The noice is similiar to what can be heard when gearing down,
If i gear down from 4th to 3rd then it also sounds more struggling and louder than before.
Any sugestions ?
Thank you.
Any sugestions ?
Thank you.
17 Apr 2014 11:02 #112411
by facade
Replied by facade on topic Drivetrain screeming noise. Vvt
Start with the obvious: is the gearbox oil level correct?
If it is, you may have a bearing on the way out, a couple of people on here have had to replace bearings in a VVT box.
The VVT gearbox is fabulously expensive, and is different to the other types (I've no idea how)
Time to create page: 0.077 seconds
