Air Bag help Needed
- parriehunter
14 Apr 2014 07:54 #112168
by parriehunter
Air Bag help Needed was created by parriehunter
I need some help. I finally found the plug under the seat for what i believe is the air bag.
The two wires have been pulled our of the plug. I have an issue as I see what colour wire goes into which hole. I am hoping to solder the wires back into the plugs as they appear to be a special one.
Can anyone please take a photo of the wires going into the plug or tell me if the black or white wire is in the middle?
Also I have a 99 Manual if that changes anything.
Thanks In Advance
Thanks In Advance
- jonesyba420
14 Apr 2014 08:49 #112170
by jonesyba420
Replied by jonesyba420 on topic Air Bag help Needed
Maybe a picture of what your looking at might help buddy.
- parriehunter
14 Apr 2014 09:08 #112171
by parriehunter
Replied by parriehunter on topic Air Bag help Needed
Here the cable that came out from under the passenger seat (left hand seat) the plug is a three way with only the two cables going into it.
The other end goes somewhere in the seat. Maybe the g sensor?
It's a bit dark outside so struggling for a good photo.
parriehunter.co.nz
parriehunter.co.nz
- markyp2000
14 Apr 2014 10:00 #112173
by markyp2000
Replied by markyp2000 on topic Air Bag help Needed
Is the air bag light on if not it may only be a sensor to pick up if any one is sitting in it as the pretensioners are fitted to the seat belt real behind the trim or it could be a seat belt clip warning to let you no if it not pluged in also is there on under the other seat my 2000 reg never had anything like that
14 Apr 2014 10:25 - 14 Apr 2014 10:25 #112174
Replied by mlines on topic Re:Air Bag help Needed
If its like the UK models then there is only an airbag module under the central console at the front. There is nothing under the seats
Sent from my Nexus 5 using Tapatalk
Last edit: 14 Apr 2014 10:25 by mlines.
The following user(s) said Thank You: parriehunter
- parriehunter
14 Apr 2014 21:02 #112230
by parriehunter
Replied by parriehunter on topic Re:Air Bag help Needed
Thanks Guys for the comments, yea the air bag light is on.
I asked this question a while ago in this post Old Post The light went off again so I just left it until it returned recently.
Time to create page: 0.108 seconds
