Jimny wont crank
  • llangatwgnedd
08 Apr 2014 16:35 - 08 Apr 2014 16:36 #111632 by llangatwgnedd
Jimny wont crank was created by llangatwgnedd
Hi all,
After running around for five miles, parked up and after five mins, jimny will not crank over.
Cleaned both terminals and still nothing, imobolsier does not flash but it does stay on when other warning lights goes off, engine mangement light stays on aswell.
Any ideas anyone? would a mobile auto dianostic get started?
2009 model.
Last edit: 08 Apr 2014 16:36 by llangatwgnedd. Reason: spelling
  • markyp2000
08 Apr 2014 16:49 - 08 Apr 2014 18:14 #111635 by markyp2000
Replied by markyp2000 on topic Jimny wont crank
Try bump starting it it may be a faulty starter motor unless its an auto
Last edit: 08 Apr 2014 18:14 by markyp2000.
  • idiotmobil
08 Apr 2014 17:40 #111638 by idiotmobil
Replied by idiotmobil on topic Jimny wont crank
mine does that now and then I put it down to crap in the starting motor from offroading or starting motor going faulty give it a wack with some thing
  • llangatwgnedd
08 Apr 2014 19:13 #111655 by llangatwgnedd
Replied by llangatwgnedd on topic Jimny wont crank
Thanks all,
After a hour and a half wait, it finally cranked over and fired up as if it was flooded, only trouble is that the engine mangement light is now on.
One thing I did notice and forgot to mention is that I did not hear the solenoid click, so I could be looking at that's the problem.
Can someone tell me that when you turn on the ignition, and it does a lamp test on warning lights, do all warning lights go out other than the oil and alternator warning light?
Time to create page: 0.096 seconds
