help !! any other way to fill gearbox oil
  • Cremator1
09 Dec 2018 18:02 #198803 by Cremator1
Replied by Cremator1 on topic help !! any other way to fill gearbox oil
Was you using the proper square socket
  • Justin83
10 Dec 2018 16:21 #198850 by Justin83
Replied by Justin83 on topic help !! any other way to fill gearbox oil
No 3/8th ratchet, what's weird is its come undone before for a level check, this time it was warm after a run so I'm guessing it got tighter when hot? Maybey the plug expanded more than the metal around it? Who knows...
  • Cremator1
10 Dec 2018 16:26 #198851 by Cremator1
Yes could have done it’s worth getting a proper set of drain plug keys they fit tighter think it’s a 10mm I tried to undo drain plug on axles with ratchet but would not shift soon as I put a 10mm plug key on it undid straight away
Time to create page: 0.628 seconds
