help !! any other way to fill gearbox oil
  • Flameboi201
04 Apr 2014 09:33 #111191 by Flameboi201
help !! any other way to fill gearbox oil was created by Flameboi201
Hi its the first service on my jimny and ive drained the gearbox oil but when ive come to fill it the fill/level bung is totaly rounded off . Is there any other way to fill it? and how much should i put in . want to be out tomoz and dont want to take box out if poss . thanks
  • Shima
04 Apr 2014 09:42 #111192 by Shima
Replied by Shima on topic help !! any other way to fill gearbox oil
I've done this before and as a temporary but tedious alternative i filled it via the breather. It took longer obviously but i just hung the bottle upside town with a pipe going into the breather and left it. Did the recommended oil amount. Can't remember exactly how much it is. But it's a way around it until you can get that bung out :)
  • idiotmobil
04 Apr 2014 10:30 #111193 by idiotmobil
Replied by idiotmobil on topic help !! any other way to fill gearbox oil
Life lesson learned here on anything ALLWAYS UNDO THE FILLER FIRST dont know if you can fill through were the lever is you can on a transferbox
  • Flameboi201
04 Apr 2014 10:31 #111194 by Flameboi201
Replied by Flameboi201 on topic help !! any other way to fill gearbox oil
Cheers dude . I welded a nut to it and got it out . Thanks anyway mate
04 Apr 2014 22:12 #111286 by Johnniehec
idiotmobil wrote: Life lesson learned here on anything ALLWAYS UNDO THE FILLER FIRST dont know if you can fill through were the lever is you can on a transferbox
Nope, definitely can't fill through the gear stick, it's a remote linkage.
  • Justin83
09 Dec 2018 13:26 #198793 by Justin83
Replied by Justin83 on topic help !! any other way to fill gearbox oil
@shima
What a life saver, on post 2005 Jimmy's the breather is easily accessible from the bay and with a massive suction syring an length of pipe managed to refill the box easily.
Wish I saw this earlier, struggled for 2 hours trying to remove a damd rounded filler plug...
Thanks.
Time to create page: 0.195 seconds
