removing rear interior panels
12 years 7 months ago #111120
by robs5230
standard jimny - for now
removing rear interior panels was created by robs5230
its time to start on my rear light rewiring so any tips on removing the rear interior side panels ? i see some screws but i'm assuming what isn't screwed on is held in place by push fit body clips.
cheers
cheers
- steffan
12 years 7 months ago #111121
by steffan
Replied by steffan on topic removing rear interior panels
BFOH
- jonesyba420
12 years 7 months ago #111123
by jonesyba420
Replied by jonesyba420 on topic removing rear interior panels
this is from memory and i could be slightly off: remove the lower seat belt anchors for the front belts, you may need to remove the little kick plate on the sill aswell. take the rear seats out (backs and bases), remove the cover on the rear door sill and remove rear lower seat belt anchors. there might be a couple of little srews on the bottom of the side panels cant remember exactly, start at the rear of the panel and pull it off the clips, the whole panel has to be pushed forward as it hooks round the front door opening if that makes sense.
easy job mate simple when your in there looking.
12 years 7 months ago #111127
by robs5230
12 years 7 months ago #111138
by Halford
The following user(s) said Thank You: robs5230
12 years 7 months ago #111144
by robs5230
Replied by robs5230 on topic removing rear interior panels
what a palava to get to a couple of wiresHalford wrote: see here
