Gearbox mount.
  • jonesyba420
12 years 7 months ago - 12 years 7 months ago #111030 by jonesyba420
Gearbox mount. was created by jonesyba420
Does anyone have the part number to give to suzuki?
the rear mount......the one that is prone to failing.
pretty sure i need one :(
Last edit: 12 years 7 months ago by jonesyba420.
12 years 7 months ago #111032 by robs5230
Replied by robs5230 on topic Gearbox mount.
i binned the packet for mine but they'll find it on the system as rear engine mount. and they will probably have one in stock. according to my stealer they're a good seller
standard jimny - for now
  • jonesyba420
12 years 7 months ago #111040 by jonesyba420
Replied by jonesyba420 on topic Gearbox mount.
so asking for a rear engine mount is the key.
is it an easy job? ie do-able on the drive with a socket set and some spanners :laugh:
12 years 7 months ago #111049 by robs5230
yeah only 3 bolts. you may have to jack the rear of the gearbox up to the body to get the new one in. it only goes up about 50mm or so but unless you have arms like a powerlifter i'd get a jack out. makes it much easier.
use a punch to make sure the mounting holes are aligned up when you drop the box onto the new mount. cured allsorts of ailments for me. 30 quid well spent
  • GuardianAngel
12 years 7 months ago #111050 by GuardianAngel
Replied by GuardianAngel on topic Gearbox mount.
robs5230 wrote: yeah only 3 bolts. you may have to jack the rear of the gearbox up to the body to get the new one in. it only goes up about 50mm or so but unless you have arms like a powerlifter i'd get a jack out. makes it much easier.
+1 or use a rachet strap around the engine to jack it forward and lift the gearbox.
12 years 7 months ago #111088 by Johnniehec
Replied by Johnniehec on topic Gearbox mount.
Must be the easiest bit of the Jimny to change, just undo the three bolts and lift the rear of the gearbox by hand, it's not heavy as the front mounts are half way along the engine. I Han mine off repaired with a couple of tywraps and back on in about 5 minutes.
The following user(s) said Thank You: GuardianAngel
Time to create page: 0.104 seconds
