Help engine light on !!!
  • Millzy
12 years 7 months ago #110844 by Millzy
Help engine light on !!! was created by Millzy
Hi every one hope you all can help me out ere . I went start my car yesterday leaving work and it was bit rough and also engine light came on I have already replaced the rear ignition coil about month ago , anyway so drove it to mates workshop and he scanned it and it came up pre ignition cyclinder 4 so then I decided to drive home because car seems to be running fine when I got home I decided to check the rear injection coil which I'm guessing is number 4 and as I pull the lead off that goes to front spark plug the lead connector just broke of inside the coil connection so hoping buy some new lead and maybe this was the problem any thoughts . Keep in mind I notice 3 times when I started it before that it ran rough for few seconds when I started it when cold ??? After that the car seemed to run perfectly fine any help be very grateful
  • j44kck
12 years 7 months ago #110857 by j44kck
Replied by j44kck on topic Help engine light on !!!
Did you read back what you wrote.
I for one am struggling to make sense of what your getting at.
  • jonesyba420
12 years 7 months ago - 12 years 7 months ago #110862 by jonesyba420
Replied by jonesyba420 on topic Help engine light on !!!
Millzy wrote: Hi every one hope you all can help me out here.
I went to start my car yesterday when leaving work and it was running a bit rough, also the engine light came on. I have already replaced the rear ignition coil about a month ago, so i drove it to a mates workshop where he scanned it and it came up pre ignition cyclinder 4.
I decided to drive home because car seemed to be running fine, upon arriving home I decided to check the rear injection coil which I'm guessing is number 4? as I pulled the lead off that goes to the front spark plug the lead connector just broke off inside the coil connection.
im hoping to buy some new leads and that maybe this was the problem, any thoughts?
Keep in mind I noticed 3 times that when I started it before from cold it ran rough for few seconds??? After that the car seemed to run perfectly fine.
dont take my edit personaly :laugh:
Last edit: 12 years 7 months ago by jonesyba420.
12 years 7 months ago #110927 by Rhinoman
Replied by Rhinoman on topic Help engine light on !!!
There is no code for pre-ignition so I will assume that what you got was 'Misfire cylinder 4'. The coil pack is a likely suspect but its worth checking that the spark plugs are good and properly gapped. If its not either of those then you will need to check compression and also fuelling on that cylinder.
  • Millzy
12 years 7 months ago #110948 by Millzy
Replied by Millzy on topic Help engine light on !!!
Hey mate I brought spark plugs 3000kms ago but they were pre gapped what is recommend gappage?
  • 410shotgun
12 years 7 months ago #110964 by 410shotgun
Replied by 410shotgun on topic Help engine light on !!!
coil packs and leads are a problem
did mine and 2 months later the rear coil played up
+ there are 2 types of leads twin cam and single cam engine they sent me the wrong type
3 times
Time to create page: 0.104 seconds
