1.6vitara 8v conversion
  • Hobbs
12 years 7 months ago #110828 by Hobbs
1.6vitara 8v conversion was created by Hobbs
Hi anyone know if a 1.6 8v carbed vitara engine will sit straight in on the same box exhaust etc eithout much mods ?
Cheers Craig
  • greenjimny
12 years 7 months ago #110836 by greenjimny
Replied by greenjimny on topic 1.6vitara 8v conversion
blocks bigger pretty sure ,same as the 16b conv
may be wrong but ??
  • Dave cc
12 years 7 months ago #110838 by Dave cc
Replied by Dave cc on topic 1.6vitara 8v conversion
Block is the bigger unit but can be fitted with the simple converter plate available from big jimny shop will only work if its a G series engine you have removed exhaust may line up but doubt it will be spot on emissions could be a problem power wise prob less than a fuel injected 1300 jimny engine you can fit a jimny head on the 8v block I have done it but I put pockets in the pistons for the valves some people say you do not need to and you would need baleno greeny blue injectors
  • Hobbs
12 years 7 months ago #110849 by Hobbs
Replied by Hobbs on topic Re:1.6vitara 8v conversion
Ill leave it then :D cheers guys ! Had the chance of s cheap engine thats all !
Time to create page: 0.083 seconds
