Replace valve cover gasket
- topjimny
12 years 7 months ago #110773
by topjimny
Replace valve cover gasket was created by topjimny
Hi all Jimnyholics,
Is this a simple job? Mine has a small leak. Is this a bad sign or happens to every good family?
Found a video with annoying music HERE and noticed he also replaces spark plug hole gaskets. What else is a go?
Also, my valve cover is a little ugly due to the previous onwer that used chemicals to clean the engine bay. Maybe i'll get new OEM nuts with no rust and give the cover a new paint on the top. Should i look for a special paint or something? Sorry for so many questions
Thks in advance, great forum
TJ
TJ
12 years 7 months ago #110841
by kirkynut
Replied by kirkynut on topic Replace valve cover gasket
I've replaced a few valve / cam covers in the last few months to a year and have found that only OE parts from the main dealer work and seal properly and you should only use rtv sealant and then only where there are half circles cut out for the ends of the camshafts etc.
- topjimny
12 years 7 months ago #110843
by topjimny
Replied by topjimny on topic Replace valve cover gasket
Thanks for the answer Kirkynut. I have done some small and general research on the web and seepage on the valve cover gasket seems to be normal on 30k+ miles engines. However, it is recommended to check the cranckcase ventilation system (PCV valve).
Time to create page: 0.083 seconds
