unplugging the airbags
- Thank you received: 77
30 Mar 2014 14:45 #110618
by robs5230
standard jimny - for now
unplugging the airbags was created by robs5230
cant seem to find where the info was, but someone posted about unplugging a connector near the gear stick to disable the airbags. can anyone give me any more info on locating this ?? i need to change my steering wheel . thanks rob
- idiotmobil
30 Mar 2014 15:21 #110621
by idiotmobil
Replied by idiotmobil on topic unplugging the airbags
the box infront the gear stick unplug that and the airbags will be disengaged and the light will be of no need to pull bulb im sure it was a metal covered box with a yellow plug
- idiotmobil
30 Mar 2014 16:45 - 30 Mar 2014 16:46 #110634
by idiotmobil
sounds the same is I done I changed the steering wheel unplugged the passenger airbag and had a light on for a wile till I read on here to unplug the ecu and the light went out
Last edit: 30 Mar 2014 16:46 by idiotmobil.
- LeeWi
30 Mar 2014 21:55 #110666
by LeeWi
Replied by LeeWi on topic unplugging the airbags
just unplug the airbag fuse in the fuse box thats the easiest option
- markyp2000
31 Mar 2014 06:36 #110680
by markyp2000
easyest isnt aways the safest just unplug the ecu or disconnect the battery
Replied by markyp2000 on topic unplugging the airbags
LeeWi wrote: just unplug the airbag fuse in the fuse box thats the easiest option
Time to create page: 0.109 seconds
