Slipping into 4 wheel drive
- Longman
30 Mar 2014 13:20 #110610
by Longman
Slipping into 4 wheel drive was created by Longman
Hi all I'm new to owning a jimny I have a problem when I go over a bump I get a loud grinding noise I have worked out it is slipping into 4 wheel drive but the lever is not moving.if I select 4 wheel drive the grinding stops has anyone got any ideas of what could be causing this
Thanks
Mark
Thanks
Mark
30 Mar 2014 14:19 #110616
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Slipping into 4 wheel drive
Broken drivers side mount on the transfer box
Grey pick up Jimny
- Longman
30 Mar 2014 14:49 #110619
by Longman
Replied by Longman on topic Slipping into 4 wheel drive
Thanks for reply is this a common fault on the jimny
30 Mar 2014 16:40 #110632
by j999pre
Grey pick up Jimny
The broken mount is yes
Grey pick up Jimny
30 Mar 2014 17:10 #110639
OMG that sounds horrible. Another common fault you say..................sigh.
Replied by helijohn on topic Slipping into 4 wheel drive
j999pre wrote: The broken mount is yes
30 Mar 2014 17:10 #110640
by robs5230
standard jimny - for now
Replied by robs5230 on topic Slipping into 4 wheel drive
could be the vac hubs sticking if not what james suggested
Time to create page: 0.095 seconds
