gearbox gearliver
if u worry u die if u dont worry u still die so why worry
Grey pick up Jimny
- GuardianAngel
j999pre wrote: Have you had the lever out? If so the plastic socket will have become dislodged, take the lever out and check behind the sliding mechanism, they normally end up there
Exactly what happened to me
Had to fish it out with a screw driver, and needed a torch to really see inside.
yes I found it there but put it back to place I dissambled it twice but still same with a lot of play the gears go in good but it is like your in neutral every gearj999pre wrote: Have you had the lever out? If so the plastic socket will have become dislodged, take the lever out and check behind the sliding mechanism, they normally end up there
Grey pick up Jimny
tks I try to see todayj999pre wrote: Centre sleeve in the spreading rod underneath? 14mm bolt
