Steering damper
  • Jutwit
12 years 7 months ago #110091 by Jutwit
Steering damper was created by Jutwit
Just got one from bits 4 vits and was wondering how to attach it? Is it pretty self evident when I get under there and look and is it 2 man job, as in does someone need to be moving the steering while I'm under it ? Sorry if it's a daft question just want to to it right
12 years 7 months ago #110107 by KJS
Replied by KJS on topic Steering damper
It can depend on which kit you got. If it's the ora kit then you have the bracket which bolts onto the box section of the chassis. There is a pic on the ora website. If it's the big jimny one then it attaches to the towing eye bracket, but you have to drill out the hole slightly. It is just a case of offering it up and making sure you are able to turn lock to lock unhindered. You can measure the damper and set it in the middle and then tighten the u bolts to the track rod. It is fairly easy to do on your own, just use axle stands and you should be able to turn the steering from underneath.
The following user(s) said Thank You: Jutwit
Time to create page: 0.067 seconds
