rear diff change
- idiotmobil
12 years 7 months ago #109990
by idiotmobil
rear diff change was created by idiotmobil
Im changing my rear diff ive not had to do any thing on there rear yet ny question is can I pull the half shafts out a bit with out taking apart the brake system only need it enough to change the diff tge slide them back in. Ive looked at the how to on chaning tge rear wheel bearings to get some clues but still unsure if I can or not
12 years 7 months ago #109995
by j999pre
Grey pick up Jimny
Replied by j999pre on topic rear diff change
No, your pipes will need to be undone. Check your bleed nipple will undo or you'll need a new n/s wheel cylinder
Grey pick up Jimny
- vitara_mad
12 years 7 months ago #110000
by vitara_mad
Replied by vitara_mad on topic rear diff change
as james says above just the brake pipes to undo to allow shafts to come out far enough to remove the diff
- idiotmobil
12 years 7 months ago #110003
by idiotmobil
Replied by idiotmobil on topic rear diff change
Cheers ill get one ordered I forgot but done the rear brakes about a month ago and every thing will undo nicely was hoping to just undovthe lot and pull it out then back in but at least I hope that means I dont have to strip brakes down as pain in arse and hate fiddly things
- idiotmobil
12 years 7 months ago #110023
by idiotmobil
cheers for the info all went well and once I looked at it properly was simple but your info helped diff will be fitted as soon as it arrives, I think it was you (vitara-mad) that sent if for skinhead, looking forward to getting it in
wile I was at it modified the plugs so now they have nut heads for easy removal also ill be pulling apart soon to change the rear bearings, one thing I could do is dot he modification I see some were to the plate I cant remember what it done or were it was but remember people saying it was a good idea any idea to what it was and were the post was (renyard possibly)
- vitara_mad
12 years 7 months ago #110026
by vitara_mad
yes I sent the diff to you from tom it was picked up today by the courier so hopefully with you tomorrow
Time to create page: 0.080 seconds
