long term plans for engine conversion
- Thank you received: 77
standard jimny - for now
It's worth looking into the 1.6 Suzuki Liana engine swap for an extra 20hp and 40% more torque. The engines come up on ebay for around £300 and you don't need to buy/fabricate any other parts to make it fit. It's a simple bolt-in swap.
my issue is... when i go off road we are moving most of the time which sort of negates low box and i dont want to be stopping all the time to change from low to high. rarely do i come across any technical stuff that demands low box and in high i can swiftly change from 4wd to 2wd as the terrain demands.
i do need the ratios i have for road use though and don't want to compromise road driving by lowering the transfer gears.
the biggest problem i have is on climbs where i just dont have enough power or torque to change up a gear and lighten the load on the engine.
the forester i had was ideal in that it was permanent 4wd and low box could be engaged on the move.
- idiotmobil
robs5230 wrote: yeah i thought about the liana engine.
You have a buzzy little 16v engine that has been designed to rev high a lot. At the moment you are probably using momentum to get you over things because you have to keep the revs up or it'll stall. With a rocklobster you can go slower and not stall, or use a higher gear if you need. The slightly lower high ratios for 2wd & high 4wd help with bigger tyres on road, putting the high ratios back to where they were as standard.
Trust us. You need a rocklobster, not a new engine.
