panhard size
  • idiotmobil
21 Mar 2014 21:48 #109441 by idiotmobil
Replied by idiotmobil on topic panhard size
yes possible but bushes look a bit suspect they don't knock or move at all but if I pull them out you never know they mite and knowing my luck brake in some way and then ill be waiting for more to turn up
I could run the rod right up the stock rod does taper down to the eyelet bit but should be fine
I guess doing that would look exactly the same as im going to do any way just have to decide if I am ever going to go higher but I dought I will or if I do I could body lift if needed
now you got me thinking more and going to have to look for some tube with a id of 25mm ( that's the size of the od of standard rod)
  • reaper
21 Mar 2014 21:52 #109442 by reaper
Replied by reaper on topic panhard size
If you do them like that you can always add a turnbuckle at a later date if you decide to do a bigger lift ( making them adjustable)
  • idiotmobil
21 Mar 2014 22:01 #109445 by idiotmobil
ya ill have to cut away some of the rod in the middle section to allow for one at a later date have to look tomarrow to see if theres any thing stopping me having 30mm tube on there don't think there should be any clearance problems and I think 30mm with a wall of 3mm should be plenty strong enough, just have to lose 1mm on the standered arm size cleaning of the rust and paint should do that measured 25mm today
Time to create page: 0.078 seconds
