Rear Half-Shafts
  • viciouspenguin
20 Mar 2014 17:05 #109284 by viciouspenguin
Rear Half-Shafts was created by viciouspenguin
I'm looking at buying a hydraulic press to do the bearings. Does anyone know the length of the longest half-shaft? I want to make sure the press has enough clearance to manage it.
20 Mar 2014 17:46 #109288 by maverick
Replied by maverick on topic Rear Half-Shafts
when you buy the press, let me know which one you get, cos I'm thinking of getting one too!!
Jalapeño, IISY?
  • TomDK
20 Mar 2014 17:59 #109290 by TomDK
Replied by TomDK on topic Rear Half-Shafts
Why not measure on the outside of the axle, from end of axle to diff housing?
You won't get the exact measurement. But I'm pretty sure it will do :)
  • viciouspenguin
21 Mar 2014 17:04 #109390 by viciouspenguin
Replied by viciouspenguin on topic Re:Rear Half-Shafts
Good thinking, but at the time I was away from the motor. I shall go measure now that I'm back!
  • viciouspenguin
21 Mar 2014 17:10 #109392 by viciouspenguin
Looks like I'll need around 90cm. Measured from the bolt pattern to the centre of the diff.
  • TomDK
21 Mar 2014 17:21 #109394 by TomDK
Replied by TomDK on topic Re:Rear Half-Shafts
If you have a big freezer you could probably press the new bearings on just by hand, by putting the shaft in the freezer overnight, and give the bearing 30-40 minutes in the oven a 200c.
I did that with the front wheel bearing. It slipped right into the hub without force or use of tools.
Time to create page: 0.150 seconds
