front wheel slop
16 Mar 2014 16:21 #108756 by Halford
front wheel slop was created by Halford
:( thought the truck was driving a bit "loose" dipping into corners and wobbling out of them :pinch:
parked up now and put my hand on top off the tyre (12'0 clock) and rocked it :ohmy:
could feel a fair bit of definite movement and even hear clunking, and it wasn't even jacked up :S
no time to investigate just now, but do kingpins fail totally as opposed to wearing
will have a proper investigate tomorrow
:unsure:
  • Bigjim91
16 Mar 2014 17:46 #108763 by Bigjim91
Replied by Bigjim91 on topic front wheel slop
Sounds like what mine was doing last week mate and that was a wheel bearing
  • gaz3359
16 Mar 2014 18:07 #108765 by gaz3359
Replied by gaz3359 on topic front wheel slop
Could be either,jack up offending wheel and try the play 12 and 6 oclock positions,then get someone to press the footbrake while doing it if the play stops will be the wheel bearing if not will be the king pins.
  • markyp2000
16 Mar 2014 19:12 #108782 by markyp2000
Replied by markyp2000 on topic front wheel slop
Mine went some where i never did find all of the bottom bearing it was that shot i had to fit another axle tube and where the bearing race knocks in on the bottom i just pushed it in and it fell back out lol
17 Mar 2014 13:45 #108833 by Halford
Replied by Halford on topic front wheel slop
:S confused.com
drove to work this morning OK and parked up, rocked the front offside wheel at 12'0 and was solid as a rock.
drove home, parked-up after a right hand full-lock turn then 1.0 m straight section, rocked the front offside wheel at 12'0 and felt sloppy movement.
jacked-up the offending wheel and rocked at 12'0 and 6'0 = only minor mm movement, had the brake applied and still minor mm movement, that means the bearing doesn't it :unsure:
while jacked up put on lock to lock and checked track rod ends, then tried at 12'0 and 6'0 and there was no rock what-so-ever, solid.
dropped the wheel and rocked at 12'0 = solid :blink:
non the wiser and more confused
  • markyp2000
17 Mar 2014 18:45 #108850 by markyp2000
Jack it up and put a bar under the tyre and lift it up while your otherhand is on the top of the wheel and see if it has any up and down movment thats what we do on the mots
Time to create page: 0.126 seconds
