New clutch neede?
- Ruby2
11 Mar 2014 14:21 #108141
by Ruby2
New clutch neede? was created by Ruby2
Hi all
I'm hoping by my little story that you'll be able to advise me if I need a new clutch?
When I purchased my 2005 Jimny about 10 months or so ago, I took the usual new car lets go for a drive to the coast. No problems with the clutch on the way there, but my wife wanted to have a drive on the way home, so I pulled over into a parking bay on a steep incline which was on a fast dual carriageway national speed limit.
As my wife put on a fair few revs and let out the clutch it do a relatively speedy set off I could smell the clutch.
Only on that occasion, it has been fine since then until.......
6 months or so later we buy a 540kg Eriba Pan Caravan and the Jimny towed it beautifully all the way home, hardly a down shift needed. It even coped with a steep gradient of start stop traffic for 1/2 mile.
Once we got it home however and I tried to reverse the van down a corner I then got a whiff of that familiar smell again
Now I wasn't sure if the caravan brakes had been applied whilst I reversed it or if it was the steep incline and the fact that I had half a dozen goes at getting it in the car park that set it off again.
I've now derived the car for a week or so and it seems to be driving as it usually does, no problem.
I can put the Jimny in a high gear whilst going slowly up a steep inline and the engine bogs down but there's no clutch slip.
The biting point of the clutch seems to be about halfway up its travel, with what feels like 2" before it bites and 2" from there to the top?
I'm just wondering what you think? Is my clutch on its way out?
We are off away with the Caravan again in April so I don't want to get stuck with it
Many Thanks
Richard
Many Thanks
Richard
- gilburton
11 Mar 2014 17:56 - 11 Mar 2014 18:02 #108169
by gilburton
Replied by gilburton on topic New clutch neede?
Easiest way is to get underneath and where the cable disappears in to the bell housing is a large plastic type knob which adjusts for free play.
Clean off the thread and apply some WD40 and leave for a few hours then adjust it until you have 2-4mm free play at the cable. Most modern cars have self adjusting cables but the Jimny is manually adjusted.
Think of it like a bike clutch cable
There is a pedal travel measurement you can try. I think it's 144mm full movement top to bottom but it's rare for it to be way out.
Last edit: 11 Mar 2014 18:02 by gilburton.
11 Mar 2014 18:09 #108172
by j999pre
Grey pick up Jimny
Replied by j999pre on topic New clutch neede?
Sounds like you've just cooked it a bit. I'm sure it will be fine just be careful maneuvering with the caravan on.
Grey pick up Jimny
- Ruby2
11 Mar 2014 18:16 #108176
by Ruby2
Replied by Ruby2 on topic New clutch neede?
Thanks chaps.
Well I'll have a look at the cable play Gilburton.
It is a bit high at the biting point for my liking, but there is about 1" or so snove the biting point before the pedal goes slack at the top of its travel.
I'll get it in to work on a ramp and have it checked.
It does seem funny that it was fine whilst I did the steep uphill start and stop with the caravan on the back and got no burning smell.
- gilburton
11 Mar 2014 18:16 #108177
by gilburton
Agreed but check the adjustment anyway.
j999pre wrote: Sounds like you've just cooked it a bit. I'm sure it will be fine just be careful maneuvering with the caravan on.
- gilburton
11 Mar 2014 18:24 - 11 Mar 2014 18:36 #108179
by gilburton
There is a plastic cover on the bell housing which you remove to get at the cable end where it fits in the fork.
A high biting point points to adjustment being needed.
You don't have to measure it but just make sure the cable end has a very small amount of slack and is not pulling on the clutch fork.
Here is a link with video but depending if the adjuster is difficult to turn you might find it easier to unhook it and then "work" it back and forward to free up the adjuster knob??
www.bigjimny.com/index.php/forum/7-jimny...o-grease-in-the-duct
Last edit: 11 Mar 2014 18:36 by gilburton.
