jimny / vitara hibrid
  • suzuki4x4breaker
09 Mar 2014 07:49 #107830 by suzuki4x4breaker
jimny / vitara hibrid was created by suzuki4x4breaker
hi im after lifting a jimny and believe i have read someone did this using vitara springs and shocks. as iv got both vitara and gv1600`s available wonderd which would be the best to do a conversion with. im guesing it will give not only hight but strengh also? is this correct. and is there any other mods then to do such as camber correction ?
iv also heard people putting vitara engines and diffs in jimnys, wich if any would be better if at all possible and what are the advantages apart from the larger engine
many thanks in advance guys
09 Mar 2014 09:21 #107845 by kirkynut
Replied by kirkynut on topic jimny / vitara hibrid
I would just buy a lift kit rather than use springs designed for another use. The spring rates will be all wrong so you'll have soft squigey suspension or hard bouncey suspension.
09 Mar 2014 09:43 #107855 by j999pre
Replied by j999pre on topic jimny / vitara hibrid
Caster correction is required with a lift. Camber is fine.
Grey pick up Jimny
  • gipcyan bill
09 Mar 2014 11:28 #107891 by gipcyan bill
Replied by gipcyan bill on topic jimny / vitara hibrid
can you use the Vit engine and box?
ive got one at work and when they are together it must be a mile long!
  • idiotmobil
09 Mar 2014 11:48 #107893 by idiotmobil
Replied by idiotmobil on topic jimny / vitara hibrid
don't use vitara springs and shocks its crap way to hard some one done it to mine before I got it and it come straight out
  • suzuki4x4breaker
17 Mar 2014 08:27 #108819 by suzuki4x4breaker
Replied by suzuki4x4breaker on topic jimny / vitara hibrid
cheers guys another thing then are the spring blocks anygood and if you use them do you also need new shocks or would you just use new springs and shocks
many thanks again
Time to create page: 0.101 seconds
