manual hubs on jimny problem help:)?
- daiwalmsley
05 Mar 2014 14:14 #107244
by daiwalmsley
manual hubs on jimny problem help:)? was created by daiwalmsley
hey guys im new btw,
recently bought my first jimny, the 4wd drive was flashing after about 20seconds of putting it in 4wd spoke to few people and read few forums. Seemed to be the vacuum system?
anyway i couldn't be bothered to find where it was broken! My mate had a vitara he was braking so i had the hubs, and then bought the plate of jimnybits and new bolts etc,
fitted them today, but know there on the car i cant seem to turn the hub from FREE to LOCK when they where of the car they turned fine?
anyone got any ideas got few pics here for you to, thanks dai.
- steffan
05 Mar 2014 14:27 #107246
by steffan
Replied by steffan on topic manual hubs on jimny problem help:)?
I had that problem when I used them same hubs and made a tool that worked a treat until one of the plastic rings split and ruined it my suspicion is that the spacer rings are a little to small as a test try slightly undueing one and then try turning it from free to lock and back again if it works there lies your problem and you will probably find a grinding disc on the hub should sort it in no time
- daiwalmsley
05 Mar 2014 14:40 #107248
by daiwalmsley
Replied by daiwalmsley on topic manual hubs on jimny problem help:)?
so try undoing the alenkey bolts? a little then try turning it?
- steffan
05 Mar 2014 14:57 #107253
by steffan
Yes then u will probably find that the ring on the hub is catching on the plastic ring that's what will need grinding back
- daiwalmsley
05 Mar 2014 15:07 - 05 Mar 2014 15:14 #107254
by daiwalmsley
yeah undun them a little turns easy what part do I need to grind down?
the spacer I bought off jimnybits or back of hub
Last edit: 05 Mar 2014 15:14 by daiwalmsley.
- steffan
05 Mar 2014 16:17 #107269
by steffan
Where the spacer go's on the hub it leaves a little lip that's what needs to come off you should see what I mean when you take the free wheeling hub cap off
Time to create page: 0.178 seconds
