winch solenoid extenshion cables
- jimny-bob
04 Mar 2014 06:52 #107094
by jimny-bob
winch solenoid extenshion cables was created by jimny-bob
www.halfords.com/webapp/wcs/stores/servl...d=255205&langId=-1an
I use battery cables
Can I use the above battery cables to extend my solenoid up into the engine bay by the air filter.
As I am aware that winches can draw huge amps?
Cheers craig
Cheers craig
- jimnydms
04 Mar 2014 08:22 #107095
by jimnydms
Replied by jimnydms on topic Re:winch solenoid extenshion cables
I have done it the way you are proposing to do and I would use at least 40mm2 cable at least. Good winch do them pre made to what ever length you want all the ends down etc. or AES (auto electrical supplies) do all the bits necessary to solder them yourself. I have been told a number of times though that the solonoid should be mounted as close as poss to the winch. But my bumper wouldn't cater for that. I am litterally doing mine at the mo so any question s I ll help as much as poss
- jimnydms
04 Mar 2014 08:24 #107096
by jimnydms
That Halfords one doesn't look beefy enough only looks like 25mm2
- Dave cc
04 Mar 2014 13:11 #107106
by Dave cc
Replied by Dave cc on topic Re:winch solenoid extenshion cables
My 8274s came standard from Warn with 35mm cable so not sure where all these bigger sizes come from ??????????????????
- jimnydms
04 Mar 2014 13:21 #107108
by jimnydms
another member recommended those sizes
- TomDK
04 Mar 2014 15:05 - 04 Mar 2014 15:07 #107121
by TomDK
35mm2 is not suitable for the Amps a winch draws a maximum pull. There is quite a noticeable drop in voltage (more than 10%), and the amps go up, causing heat and potential damage to the motor.
People can use whatever cable they find sufficent. But I only find 35mm2 sufficient for greenlaning and occasional winhing. More frequent winching a comp, 50/60mm2 or bigger.
Also, the 8274 is only a 8000 lb winch with a 4.6 hp motor. So perhaps 35mm2 cable will do a little bit better, than on a 9500 lb winch with a 5.6 hp motor.
Replied by TomDK on topic Re:winch solenoid extenshion cables
Dave cc wrote: My 8274s came standard from Warn with 35mm cable so not sure where all these bigger sizes come from ??????????????????
Last edit: 04 Mar 2014 15:07 by TomDK.
Time to create page: 0.087 seconds
