vacuum hub help please
  • Gjmcleod
02 Mar 2014 10:21 #106797 by Gjmcleod
vacuum hub help please was created by Gjmcleod
Hi all ,, I am stripping & rebuilding my front axle , renewing all the bearings & seals ,,, the car is only used off road , I have read all the other hub posts , but most are for on & off road use ,,, my question is , if I refit the vacume hub , in the 4 wheel drive position , & just block off the pipes at the back hub , will it stay in that position & be 4x4 permanently ???? I have no need to put into 2 WD,thanx
  • steffan
02 Mar 2014 10:31 #106798 by steffan
Replied by steffan on topic vacuum hub help please
I would be tempted to stick a blob of silicone in behind to just stop them from moving
02 Mar 2014 13:00 #106825 by robs5230
Replied by robs5230 on topic vacuum hub help please
i did this on a trooper and it did stay put. if id doesn't its only the top plate off to cure it
standard jimny - for now
  • Gjmcleod
02 Mar 2014 13:13 #106826 by Gjmcleod
Replied by Gjmcleod on topic vacuum hub help please
Great thanx guys , I will carry on with no vac pipes ;)
  • MWells
02 Mar 2014 17:21 #106854 by MWells
Replied by MWells on topic vacuum hub help please
I've had that set up on my road going jim for 18 months, just move the transfer lever from 2wd to 4wd when i want it. Hasn't had any adverse effects and i know when the lever is in 4wd i have 4wd.
  • helijohn
02 Mar 2014 19:41 #106886 by helijohn
Replied by helijohn on topic vacuum hub help please
MWells wrote: I've had that set up on my road going jim for 18 months, just move the transfer lever from 2wd to 4wd when i want it. Hasn't had any adverse effects and i know when the lever is in 4wd i have 4wd.
Me too in that I have the front engaged at all times.
Time to create page: 0.107 seconds
