Crankshaft Pulley - help!!!
- MalcolmB
28 Feb 2014 18:47 #106514
by MalcolmB
Crankshaft Pulley - help!!! was created by MalcolmB
Hi All...
Hope somebody can help here.
The crankshaft pulley on my Jimny has fallen to bits! It's the 13A dohc engine.
The outer part has separated from the inner part - the rubber sleeve has given way, although it's only torn in one tiny place. Is this common? It's got 80,000 miles on the clock.
Has anybody got a spare thay can sell me or know where I can get one?
Also - what's the best way to remove the bolt? I've searched the forum and it looks like either a long breaker bar, top gear, brakes on and lots of heaving, or wedge the breaker bar on the chassis and blip the starter.
I'm terrified of snapping the bolt head off. I've got an impact style six flat socket so I'm not too worried about rounding it. I've also got one of those 12V impact wrenches that I'll try but I don't hold out much hope for that.
I'm also toying with the idea of trying some two part acrylic glue as a temporary repair but I don't really want to put everything back together just to take it apart again to put a proper part on.
Cheers
Malcolm
Cheers
Malcolm
- markyp2000
28 Feb 2014 19:44 #106526
by markyp2000
Replied by markyp2000 on topic Crankshaft Pulley - help!!!
Blip the starter id unplug the coils so it wont start iv dont this may times and its never failed just makes a bit of noise
- MalcolmB
28 Feb 2014 20:18 #106543
by MalcolmB
Replied by MalcolmB on topic Crankshaft Pulley - help!!!
Thanks for the fast reply.
Cheers
Malc
Cheers
Malc
- MalcolmB
01 Mar 2014 09:32 #106622
by MalcolmB
wORKED A TREAT!!! Thanks - I'll know what to next time.
Malc
Malc
01 Mar 2014 10:35 #106626
by facade
Very common, a new one from Suzuki will make your eyes water, you'll be very lucky to find a breaker who will sell you one, and good second hand ones are like rocking horse droppings/hen's teeth (depending on where you were brought up)
Someone on here successfully fixed his by drilling into the pulley, tapping and fitting 3 grubscrews from outer to inner.
We were all waiting for him to report that his crank had broken, but it never did. (The pulley is a damper, designed to stop oscillations in the crank, at certain engine speeds that you might never use, that can break the crankshaft.
Replied by facade on topic Crankshaft Pulley - help!!!
MalcolmB wrote: Hi All...
- MalcolmB
01 Mar 2014 12:50 #106641
by MalcolmB
Hi...
Thanks for the info
I might try the grub screw trick. I've located a used one for about 60 quid but I need it in a hurry so I'm biting the bullet and buying one from a local dealer. About 150 quid including vat!!!
Ay least I'm saving the fifty quid or so an hour labour charge.
Cheers
Malc
Thanks for the info
Cheers
Malc
Time to create page: 0.092 seconds
