diff oil leak ??
  • idiotmobil
28 Feb 2014 19:45 #106527 by idiotmobil
Replied by idiotmobil on topic diff oil leak ??
gipcyan bill wrote: easy peasy job as long as you have the bearing tool
there is no bearing tool for the king pins stop confusing him
  • TomDK
28 Feb 2014 19:46 #106528 by TomDK
Replied by TomDK on topic diff oil leak ??
markyp2000 wrote:
TomDK wrote: Sorry.. Just trying to point out, that if he can change a wheel, he can also do this :)
It is pretty straightforward, bolt-off bolt-on thing :)
most things are bolt off bolt on but most people lack confidence to do the work my mum can change a wheel but could not carry out a full engine rebuild :lol: :laugh: :P
Of course you're right :)
I just meant, it's easy to do, requires no special tools, no heavy lifting and nothing that needs to be aligned with anything afterwards :)
And no, bearing tool is not required. I used a 32mm socket to knock out the bearing races.
  • gipcyan bill
28 Feb 2014 19:48 #106530 by gipcyan bill
Replied by gipcyan bill on topic diff oil leak ??
thought it made the job easy if you pulled the lot off
if its in a million bits surely you may as well give every thing the once over re grease etc
or is that me being over enthusiastic
  • gipcyan bill
28 Feb 2014 19:52 #106532 by gipcyan bill
[quote
And no, bearing tool is not required. I used a 32mm socket to knock out the bearing races.[/quote]
so whats this for?
or do you just smash that out as well
  • idiotmobil
28 Feb 2014 19:53 #106535 by idiotmobil
gipcyan bill wrote: thought it made the job easy if you pulled the lot off
or is that me being over enthusiastic[/quote
no need to touch the wheel bearing if its not going makes the job easyer if you don't do all the steps of the walk through
  • idiotmobil
28 Feb 2014 19:55 #106536 by idiotmobil
gipcyan bill wrote: [quote
so whats this for?
or do you just smash that out as well[/quote]
that would be a wheel bearing tool he wants to change the kingpins did you skip reading the first few posts
Time to create page: 0.105 seconds
