HELP PLEASE ANYONE
  • sue
12 years 8 months ago #106480 by sue
HELP PLEASE ANYONE was created by sue
The other night driving home from work i usually just take my foot off the accelerator and let the jeep roll down to the traffic lights , but as i lifted my foot the car sort of snatched back so i pressed my pedal and lifted did the same again didnt think much off this till i got to the lights when i stopped and the engine was ticking over at a good 1500 revs my first thought was stuck cable so i revved and released quickly but it really went down slowly from 1100 to what i can say is about 950 revs , its been fine till today while traveling along the A1 when i lost power twice and i was only going about 60 ish its sure not happy seems sluggish anyone have any ideas how i can make my little green jeep happy again
  • gipcyan bill
12 years 8 months ago #106604 by gipcyan bill
Replied by gipcyan bill on topic HELP PLEASE ANYONE
have you tried turning it off then on again :)
  • sue
12 years 8 months ago #106606 by sue
Replied by sue on topic HELP PLEASE ANYONE
ha ha and yes i do have petrol in it before you ask
12 years 8 months ago #106627 by facade
Replied by facade on topic HELP PLEASE ANYONE
Have a look to see if any of the pipes from the manifold are split/dropped off, especially the one to the hub vacuum system.
Holding back/low top speed could be a seized brake (very common), or collapsed wheelbearing, a flat tyre (don't laugh- I've seen it) blocked catayst, failed pre-cat lambda sensor, blocked air filter, seized alternator (but it would be noisy and overheat and the ignition light would be on), cam seizing due to dirty/non existent oil, running in 4wd, no oil in axle.
High idle could be seized idle air controller, air leak, stuck throttle butterfly, faulty crank/cam sensor and may or may not be related to the holding back.
I assume the EML is not on, but you could still get the codes read to see if there are any clues.
Loss of power/cutting out is usually crank sensor.
So, patronising as it sounds, the best advice is a thorough service to check all the levels, wheelbearings brakes and pipework and look for obvious faults, before starting to delve inside the engine.
  • gipcyan bill
12 years 8 months ago #106708 by gipcyan bill
thankyou for the reply
Time to create page: 0.088 seconds
