wheel spacer
- minare
26 Feb 2014 07:55 #106148
by minare
wheel spacer was created by minare
hey
i use 1" (25mm) wheel spacers
i think to change them (have a buyer) to wider ones
i love the spacers, feels lot of improvement off road, much more flex.
i think to use 35mm of 38mm (1.5")
what do you thinkabout this change and from experience if there is affect on bearings or other parts from the new spacers, something different than what i have now
Thanks
Guy
Thanks
Guy
- Fearghal Murphy
25 Mar 2014 23:31 #110101
by Fearghal Murphy
Replied by Fearghal Murphy on topic wheel spacer
Yes the larger wheel spacers (mine are32mm) will cause wheel bearings to prematurely fail, and fail very badly. I have replaced 3 wheel bearings in the last 18 months, getting very good at it now. I am taking the spacers off now as I am unable to do much off road driving at all anymore.
I have also experienced major brake problems due to the catastrophic failure of front wheel bearings.
Hope this helps and good luck !
- GuardianAngel
25 Mar 2014 23:38 #110103
by GuardianAngel
As have I and at least one other on this forum.
Replied by GuardianAngel on topic wheel spacer
Fearghal Murphy wrote: I have also experienced major brake problems due to the catastrophic failure of front wheel bearings.
- Fearghal Murphy
25 Mar 2014 23:41 #110104
by Fearghal Murphy
Haha sure i was only reading the thread about your trials and tribulations the other day! The only times I ever had brake trouble/failure was when my front right wheel bearing went, and then the left one last week !
I have access to a press etc. so can do the bearings nice and quickly now! Removed my spacers today, need to get some value out of this work !
I would say you were going nuts until you sorted your brake issues !
- GuardianAngel
25 Mar 2014 23:54 #110105
by GuardianAngel
Yes I was, and spent a fortune on replacing a load of brake parts :'(
But at least it's all in top notch condition now
Replied by GuardianAngel on topic Re:Re: wheel spacer
Fearghal Murphy wrote: I would say you were going nuts until you sorted your brake issues !
Time to create page: 0.098 seconds
