Balancing beads
  • Nelson83
25 Feb 2014 10:19 #105970 by Nelson83
Balancing beads was created by Nelson83
Had a quick search through the archive posts on balancing beads - seems like everyones happy with them, but anybody else tried them since and willing to share their experiences? My truck has started to develop a death wobble again and the passenger wheel has started to almost "saw teeth" as the tyre fitter said today (local independent place that is willing to work for cash :whistle: ). Just thinking is it worth getting a set of bags for them and when i order a new tyre and get them to fit it, to get them to pop the rims on them all and chuck a bag in each wheel.
Its definately not the suspension/ king pins/ bearings or brakes as they were all done at the end of 2013 - the death wobble returned so i had the lot changed (its a second hand axle, and i wasn't sure when everything was done). All new bits as my local garage that likes pound notes also got me to get the bits in advance
  • Yellostreak
25 Feb 2014 19:39 #106019 by Yellostreak
Replied by Yellostreak on topic Balancing beads
No eBay APP ID and/or Cert ID defined in Kunena configurationI read somewhere that these puncture prevention solutions do the same job as balance beads but have the additional advantage that they will seal a puncture.. ones on fleabay and have some remarkable claims on hole size..
  • supergaz
25 Feb 2014 22:55 - 26 Feb 2014 07:45 #106107 by supergaz
Replied by supergaz on topic Balancing beads
I have balancing beads and they do work well, but if you have balancing beads and still have wobble then the problem of wobble will lie elsewhere. A generally overlooked area is to remove the disk and ensure the mating surface between the hub and disk are clean and also that the surface between the wheel and brake disk are clean. Also ensure the wheels are fitted correctly with the wheel nuts torqued in the correct order.
Last edit: 26 Feb 2014 07:45 by supergaz.
26 Feb 2014 00:38 #106139 by kirkynut
Replied by kirkynut on topic Balancing beads
I use balancing beads with good effect and I'm happy with then. Got them from Devon 4x4.
  • pkitchen123
26 Feb 2014 12:55 #106186 by pkitchen123
Replied by pkitchen123 on topic Re:Balancing beads
You have to torque the wheel nuts in a set order !?!? Anyone know this order ?
  • MWells
26 Feb 2014 15:18 - 26 Feb 2014 15:19 #106211 by MWells
Replied by MWells on topic Balancing beads
Yellostreak wrote: I read somewhere that these puncture prevention solutions do the same job as balance beads but have the additional advantage that they will seal a puncture.. ones on fleabay and have some remarkable claims on hole size..
Tried similar to this in the work van, it sealed the puncture but made it undrivable above above 35mph, it made death wobble seem mild.
Last edit: 26 Feb 2014 15:19 by MWells. Reason: fat fingers small keys
Time to create page: 0.101 seconds
