CV joint?
  • Biasmechanic
12 years 8 months ago #105883 by Biasmechanic
CV joint? was created by Biasmechanic
I'm pretty sure the passengers side cv has gone on my 2000 soft top. Just wanted to see if you guys agree with my diagnosis. There is a knocking coming from the front corner when at full lock (in 2wd or 4wd but im also sure the hub on that side is sticking on as doesn't clunk much when shifting between 4 and 2 and vice versa). When out laning the other day there was a loud clicking from the passengers side accompanied by the steering wheel snatching side to side. Heres a link to a video my mate got of the noise.
Im sure it is the cv but just what others opinions before I buy a replacement and start stripping it down. Also do soft tops run different cvs to hardtops? If so would i be better getting a cv and shaft from a hardtop?
Thanks for your help.
  • idiotmobil
12 years 8 months ago #105887 by idiotmobil
Replied by idiotmobil on topic CV joint?
sounds like cv just strip down and have a look its a reasonably easy job to do there are two different splines on shaft there 19 and 20 or 21 will need to strip down to be sure
12 years 8 months ago #105890 by robs5230
Replied by robs5230 on topic CV joint?
hard to call for me , too much background noise in the vid. when the jim could not go on at first the offside front wheel was spinning and the nearside had no drive ( i'm presuming this is the point where the clicking was). on the second attempt the front nearside wheel was driving. the knocking on full lock and the clicking may be 2 different things. surely a shot cv wouldn't have intermittent drive ? but a sticky vac hub would definitely. i replaced vac hubs with manual hubs on my jim and a trooper before that. typically sticking vac hubs will either not disengage from 4wd or not engage, both causing clicking. easy to check the hubs, disconnect vac pipes , fold the pipe and tie with a cable tie or block in some manner . pop the front plate off the vac hub and engage the collar manually with your finger ( they will just slip into place ). vac hubs will then be fixed. if clicking does not continue in or out of 4wd its the hubs at fault.
easier and cheaper than stripping for cv's. if the vac hubs are at fault i'd replace with manual hubs. this way you can leave all the vacuum hoses intact and just engage hubs from outside when you need them. rob
standard jimny - for now
  • idiotmobil
12 years 8 months ago #105894 by idiotmobil
if you can do it you self I would still suggest stripping the lot down and regreasing every thing as you go blow the kingpin bearings out with a compressor and repack with grease as they will last a lot longer if done I do this both side every now and then and my current kingpins have lasted a lot longer the bottom one will proberly be nasty but blown out and repacked will last a lot longer
  • Biasmechanic
12 years 8 months ago #106268 by Biasmechanic
Replied by Biasmechanic on topic CV joint?
I stripped it all down today and found a couple of things. Firstly the hub was in the disengaged position and when i tested it, seemed to be working fine, moving quite freely so perhaps the hub wasn't sticking as I previously thought. With the hub removed turning the drive shaft by hand I could hear and feel a clicking from the shaft. I stripped it down further and found the whole hub assembly didn't swivel freely. Completely stripped down I found the bottom kingpin bearing was typically filled with muck. Despite there being no play Ill replace the bearings as even after cleaning up the bottom one was still a bit crusty and might as well do it whilst its apart. Previously when a cv went on my old nova that was very obvious with you being able to waggle the shaft around with out the hub moving. I unfortunately ran out of degreaser at this point so couldn't completely clean the joint out , I will do this and investigate more when I've got some more degreaser.
What I did notice is black spots on the outside of the joint that correspond to where the balls are in inside. I've never seen this on another cv before and almost looks to me like heat damage? Is this normal? Also any tips what to look for when I get the cv cleaned up as all I can tell so far is that it isn't completely smashed.
Again thanks for the help.
  • idiotmobil
12 years 8 months ago #106275 by idiotmobil
Biasmechanic wrote: I stripped it all down today and found a couple of things. Firstly the hub was in the disengaged position and when i tested it, seemed to be working fine, moving quite freely so perhaps the hub wasn't sticking as I previously thought. With the hub removed turning the drive shaft by hand I could hear and feel a clicking from the shaft. I stripped it down further and found the whole hub assembly didn't swivel freely. Completely stripped down I found the bottom kingpin bearing was typically filled with muck. Despite there being no play Ill replace the bearings as even after cleaning up the bottom one was still a bit crusty and might as well do it whilst its apart. Previously when a cv went on my old nova that was very obvious with you being able to waggle the shaft around with out the hub moving. I unfortunately ran out of degreaser at this point so couldn't completely clean the joint out , I will do this and investigate more when I've got some more degreaser.
keep hold of the top king pin as a spare if its good as the top usealy is then next time you check and the bottoms knackered again you can pop the old top one in and your good for longer with out spending more
Time to create page: 0.087 seconds
