HELP ME !!! PLEASE OVERHEATING PROBLEM
- Millzy
12 years 8 months ago #105819
by Millzy
HELP ME !!! PLEASE OVERHEATING PROBLEM was created by Millzy
ok so here goes fello jimmy lovers my lil jim is a manual 05 model it has 227000 kms on it but is in very good condition besides this one small problem ok well I live in Australia so bare that in mind that 38 degree days are not uncommon ...
2 weeks ago now I was driving along highway at around 90kms with aircon on all of sudden aircon blowing warm air and looked at temp gauge and was way over so turned aircon off and pull over and it dropped right down again turn air con on started driving went up again so drove rest way home with air con off .. got home filled up radiator as fluid had gone into the overflow tank but not returned into radiator ??
This same thing happen yesterday again bare in mind was another scorcher hot day 38 degrees while driving home with the missus down high way aircon on same thing radiator fluid went into overflow tank but again did not return once cooled down .. so I decided to see how I went today driving home from work all was fine but again I got home popped the bonnet sure enough the over flow tank was near full but didn't seem to reclaim it fluid back?????
ok so I brought a thermostat and gasket today haven't put it on yet thinking this may be problem also I have xrox bar with big spotties on it that actually look like they would bloke the air flow to under the hood you know were the vents are on front of the bonnet so thinking maybe if I take them off ........Also before anyone asked I have checked to see if has a cracked head or head gasket blown but checked seems to be no bubbles in radiator and oil looks perfect and besides the overheating the engines seems to be running like clock work ... I love my little jimny and any help would be really appriecated as I plan many more trips with my little family in our little beast !!!! oh also I was maybe thinking could this be a radiator cap problem !!
- Millzy
12 years 8 months ago #105826
by Millzy
Replied by Millzy on topic HELP ME !!! PLEASE OVERHEATING PROBLEM
anybody !!!!!!!!!!!
- gilburton
12 years 8 months ago - 12 years 8 months ago #105827
by gilburton
Replied by gilburton on topic HELP ME !!! PLEASE OVERHEATING PROBLEM
Well the spots are certainly blocking the airflow especially in the temps you get over there. so that would be my first point to remove them and see if there is any improvement?
Apart from that check out the hoses as they have been known to go soft and collapse when a vacuum is required to return the coolant to the radiator.
Also check out the rad cap as this is actually a bit more complex than just a cap as it has valves in it that allow the coolant to flow either way.
There was a post about this a couple of weeks ago?
I know it says VVT but I think they are the same??
www.bigjimny.com/index.php/forum/7-jimny...ooling-problem#96126
Last edit: 12 years 8 months ago by gilburton.
- Millzy
12 years 8 months ago #105831
by Millzy
thanks mate ill check that out ill have make sure I get hold of a genuine Suzuki cap hope this is all it is
- JuanGuillie
12 years 8 months ago - 12 years 8 months ago #105841
by JuanGuillie
Replied by JuanGuillie on topic HELP ME !!! PLEASE OVERHEATING PROBLEM
Just some idea's :
Could be your lights might have something to do with this problem but also the metal plate where your numberplate is bolt on could be (a part of) the reason.
This protection seems to covering the most important air flow to your radiator.
You could put some hole's into it to let air get trough to your radiator.
Are these lights and protection already longtime on your Jimny ?
Did you already cleaned out your radiator by flushing it?
Take out the thermostate from your radiator, don't think you need a lot of heating for the time being.
Engine temperature will be fast enough on it's regular needed temperature, if problem is solved by doing this then you now you have to buy a new thermostate.
Succes !
Succes !
Last edit: 12 years 8 months ago by JuanGuillie.
12 years 8 months ago #105916
by kirkynut
Replied by kirkynut on topic HELP ME !!! PLEASE OVERHEATING PROBLEM
Hi there, apologies I'm a bit late to the party but not been on here much the last week or so as had things going on.
Firstly its not the lights.
It could be a number of things. Such as:
Thermostat stuck shut. You've fitted a new one, so that's one less thing.
Blocked rad, either inside or the cooling fins outside blocked with mud etc.
Viscous fan viscous unit no longer working and not locking up like it should.
Water pump packing up, impeller coming disconnected from the shaft.
My money is on the viscous unit failing.
Time to create page: 0.099 seconds
