King Pin Bearings !
  • Fieldsports
21 Feb 2014 20:30 - 21 Feb 2014 20:32 #105461 by Fieldsports
King Pin Bearings ! was created by Fieldsports
Hello.
Just want some advice for the future if you can help.
I just replaced the king pin bearings with 30302J2 Metric Single Row Taper Roller Bearing 15x42x14.25mm
As I have been told that the J2 bit of the bearing number means manufactured to a recognized std and tolerance.
But I have found 30302 bearings that are exactly the same size 15x42x14.25mm
I compared the two bearings with a digital micrometer and they measure the same as well.
Can I ask a silly question here why is the 30302 bearings not recommended for the kingpins when all I can see is different is the price which is quite a bit.
Thanks for any advice ! :blush:
Last edit: 21 Feb 2014 20:32 by Fieldsports. Reason: Forgot to check subscribe to topic
21 Feb 2014 20:56 #105466 by mlines
Replied by mlines on topic Re:King Pin Bearings !
The J designation tells you about the cage. J2 = pressed steel cage, rolling element centered, new design for single row tapered roller bearings;
Sent from my Nexus 5 using Tapatalk
Time to create page: 0.077 seconds
