More Steering Lock on one side
  • Fieldsports
12 years 8 months ago #105340 by Fieldsports
More Steering Lock on one side was created by Fieldsports
Hello.
I have just done the kingpin bearings on the drivers side of my Jimny.
2007 Model
They were shocking well the bottom one was.
Totally disintegrated bearing and shattered race on the bottom.
I really left this too long before fixing it.
So I spent what I had spare on some bearings and it seemed to work fine.
No play on either side wheel now and wheels sitting nice and straight again.
I have suddenly noticed the steering turns two full turns to the left and only just over 1 and a half to the right.
I have never noticed if it has always been like this.
Obviously I have not altered anything and all joints are correct and no steering bars bent.
Very curious to see what it could be !
Its not bothering me too much but if it is a fault I would correct it.
Apart from that it drives very well and now the kingpins are done no more grease leaks and clonks.
Any advice appreciated.
Thanks
  • markyp2000
12 years 8 months ago #105385 by markyp2000
Replied by markyp2000 on topic More Steering Lock on one side
Take your steering bars off and see if the hubs turn the same amount
  • Fieldsports
12 years 8 months ago #105387 by Fieldsports
Replied by Fieldsports on topic More Steering Lock on one side
markyp2000 wrote: Take your steering bars off and see if the hubs turn the same amount
Yep that's what I did honest !
I was working on the drivers side where only 1 joint needed to be removed,
Full angle swings.
Went to the passenger side. ( Not done bearings but have shimmed them ) bought shim kit from Martin.
Took joints off and seemed to work similar ! Same looking angles
I will be honest I have not measured the drag or the degree but does look the same.
The drop arm off the steering box looks a little off center when the bonnet is lifted !!!!
Do not know where it should be but mine is on a P1ss
I have not tried to adjust this yet as I was wanting advice from you guys before I begin.
Thanks Steve
  • Fieldsports
12 years 8 months ago #105388 by Fieldsports
PPS if the hubs did not turn the same what would that be in your opinion.
can't see how if they move 100% side to side with nothing attached what the problem can be ?
Sorry to ask more but why is this shitty problem here....LOL
Its not stopping me from driving but it would be nice to fix it and know.
That's if they aren't like that anyways ??????
Thanks Steve
