Exhaust Modification opinions !
  • Fieldsports
20 Feb 2014 20:58 #105338 by Fieldsports
Exhaust Modification opinions ! was created by Fieldsports
My back box on my 2007 Jimny seems to be "near to blow" stage in its life.
This has caught me right at a time when I can not afford a replacement back box.
So here is my thoughts !
The exhaust goes along the back as we know
I was thinking to dismiss that and mount it on the other side.
Look at the pic taken from the back as to where the exhaust back box is attached .
From the flange there is 10 inches and 6 inches wide to get a silencer in.
I could cut the middle pipe shorter to fit a longer silencer of course and bore a hole about in the red circle in the other pic to stick the tailpipe out.
Do you think that's a bad Idea or maybe a thought.
I can probably get a middle box or a small back box from a car for nothing off my mate that has a breakers yard.
I have all the welding gear needed if I do need to weld I do not mind
Any suggestions or has anyone else done something similar ?
Thanks
  • idiotmobil
20 Feb 2014 21:13 #105341 by idiotmobil
Replied by idiotmobil on topic Exhaust Modification opinions !
motorbike exhaust has been done a lot and proves to be a good idea
  • Fieldsports
20 Feb 2014 21:16 #105342 by Fieldsports
Replied by Fieldsports on topic Exhaust Modification opinions !
idiotmobil wrote: motorbike exhaust has been done a lot and proves to be a good idea
Are they not boy racer loud ! :blink:
I was hoping to get a normal sounding jimny
But if motor bike silencers work I could get one.
Thanks again
20 Feb 2014 21:38 #105349 by Halford
renard38's Jimny is pretty cool - check it out here
  • winter
20 Feb 2014 21:39 - 20 Feb 2014 21:43 #105350 by winter
Replied by winter on topic Exhaust Modification opinions !
iv used a middel box off my old sunny gti-r as a rear box on my jimny with a 3 1/2" tailpipe sounds great not to much she sounds like a v8 at times on low speeds and turboie when you open the taps :)
some iv heard sound like a bubble machine :huh:
Last edit: 20 Feb 2014 21:43 by winter.
  • Fieldsports
20 Feb 2014 21:52 #105355 by Fieldsports
Great mods ! they look really good.
I was hoping to go down the "Normal Noise" route if at all possible.
I also do pest control where I have to drive the fields so was hoping to keep the sound down
to as quiet as possible.
My age does not justify loud exhausts either LOL
Time to create page: 0.092 seconds
