Adjustable panhard rods
- GuardianAngel
20 Feb 2014 22:11 #105360
by GuardianAngel
Could be knackered bushes on your radius arms. I had to hack saw some of the bolts off on of mine tonight (so I can eventually fit my last guard!) and the bushes were beyond fecked.
I always had a clonk when driving around but after fitting a new arm with decent bushes it has almost gone away. Just probably the other side needs sorting to eliminate it. The axle bracket holes are not elongated either so it was not that causing it.
Replied by GuardianAngel on topic Adjustable panhard rods
jonesyba420 wrote: Mine clunks when flexing and im standard :dry:
- mc_nebula
23 Feb 2014 19:14 - 23 Feb 2014 19:16 #105693
by mc_nebula
Replied by mc_nebula on topic Adjustable panhard rods
Panhard rods were bushed from factory for a reason. The Rose joints are noisy insofar as when you turn the wheel the front joints clunk. The rear joints clunk when you corner.
The clunk is down to the clearance hole between the rose joint and the bolt. I found it introduced steering play too.
The spacers sold with them are too narrow and you will end up crushing your mounts too. I've got rid of mine from my truck and fitted jimny bits ones. no clunking, no steering play again and a quieter ride.
I contacted ORA about this, and the line from them was that it was my error in fitting them. I don't buy this, as fitting JimnyBits ones solved the problem.
If you still want the ORA ones, and are reasonably local to North Hampshire (Fleet) I have a set of ORA ones and the spacers you need too, I'll sell them to you for a reasonable price?
Last edit: 23 Feb 2014 19:16 by mc_nebula.
- Dan_T
23 Feb 2014 19:34 #105702
by Dan_T
Replied by Dan_T on topic Adjustable panhard rods
Thanks for all help peeps! Im going to wait until jimnybits gets some in stock and buy a set from them.
Time to create page: 0.108 seconds
