King ping removal
  • ne-crock
12 years 8 months ago #105179 by ne-crock
King ping removal was created by ne-crock
Right had a look for a topic can't see one,
All set up ready to strip my kingpin down,
Then noticed the step for needing to split the steering arm, I don't have a bearing puller can I just swivel the hub out the way rather than splitting it?
Or if not any smart ideas for splitting it?
Cheers
Mike
12 years 8 months ago #105183 by safari
Replied by safari on topic King ping removal
on the drivers side where there is only one baljoint u do not need to remove it but on the pasinger side there r 2 u need to remove 1 at least , just release the nut and hammer it down tip to hammer place the nut on and hammer on it not on the baljoint it is supposed to pop down
if u worry u die if u dont worry u still die so why worry
The following user(s) said Thank You: ne-crock
  • ne-crock
12 years 8 months ago #105188 by ne-crock
Replied by ne-crock on topic King ping removal
thats what i like to hear,
cheers
i'll crack on
12 years 8 months ago #105192 by facade
Replied by facade on topic King ping removal
Don't hammer the threaded part down :ohmy:
The bolt/pin is tapered. How to get it out is lay a lever across the arm to give it a reason to drop out, then strike the end of the arm (the eye part) directly in line with the arm, hard.
This will shock the taper oval, and the ball joint will fall out.
Be careful not to catch the rubber boot with the hammer.
  • GuardianAngel
12 years 8 months ago #105198 by GuardianAngel
Replied by GuardianAngel on topic King ping removal
MachineMart do splitters cheap. I got a set to do the exact same job and they come apart really easily and quickly.
12 years 8 months ago #105204 by safari
facade wrote: Don't hammer the threaded part down :ohmy:
done both sides yesterday with no problem just screw the nut back and hammer on it
Time to create page: 0.088 seconds
