cv vs crosses
18 Feb 2014 08:03 #105007 by safari
cv vs crosses was created by safari
I was reading in another place that a cheaper way of having more hd cv is to change them to crosses .I know here r more technical people than me and would like your ideas or if anyone has tried it before
if u worry u die if u dont worry u still die so why worry
  • TomDK
18 Feb 2014 08:23 #105008 by TomDK
Replied by TomDK on topic cv vs crosses
safari wrote: I was reading in another place that a cheaper way of having more hd cv is to change them to crosses .I know here r more technical people than me and would like your ideas or if anyone has tried it before
You mean universal joints, like Dana axles? Anything is possible, but you'll have to Install the entire axle not just the shafts and joints.
18 Feb 2014 09:33 #105014 by mlines
Replied by mlines on topic Re:cv vs crosses
And as I understand it, you would need to install 2 UJs to replace one CV.
Sent from my Nexus 5 using Tapatalk
18 Feb 2014 10:21 #105018 by safari
Replied by safari on topic Re:cv vs crosses
mlines wrote: And as I understand it, you would need to install 2 UJs to replace one CV.
but will it be stronger than cv ? and I make a hd shaft to suit the ujs
  • TomDK
18 Feb 2014 10:34 - 18 Feb 2014 10:36 #105022 by TomDK
Replied by TomDK on topic Re:cv vs crosses
You'll need open knuckles, to suit the U joints. Just fitting them in the jimny knucke makes little sense.
You don't need 2 U joints to replace on CV. Take a look here:
This is from a Dana 60 front axle. As you can see it's completely different to the CV joint. Which is why it is way easier to install a complete front axle with open knuckles/U-joints.
A Dana 30 front axle from a Jeep should be fairly easy to find, this also has U-joints.
Last edit: 18 Feb 2014 10:36 by TomDK.
18 Feb 2014 11:02 #105025 by safari
TomDK wrote: You'll need open knuckles, to suit the U joints. Just fitting them in the jimny knucke makes little sense.
tks just thinking of more options as the cv r breaking too easy just with 31' tyres
Time to create page: 0.099 seconds
