Making 31's fit
- robp
17 Feb 2014 18:17 #104917
by robp
Making 31's fit was created by robp
I have been offered a set of 31's to put on my Jimny and as i need a new set I'm thinking i might as well see if i can make them fit ok. My Jimny is a 99 hardtop auto, currently fitted with a 2" spring lift and new shocks and extended brake lines. I am not adverse to the idea of trimming arches, but i don't want to go too crazy.
I am thinking that a 2" body lift would help, hopefully doing the trick. I assume that this would include me needing to extend the steering column and the transfer box lever, but really nothing else. Am i being a bit nieve?
Any comments would be appreciated as this is the first.
Thanks.
Thanks.
- idiotmobil
17 Feb 2014 18:22 #104919
by idiotmobil
Replied by idiotmobil on topic Making 31's fit
don't forget about gearing with 31s it would be terrible and then blow cvs a lot more often
- geraint
17 Feb 2014 18:44 #104923
by geraint
Replied by geraint on topic Making 31's fit
should do the trick mate
- robp
17 Feb 2014 19:10 #104931
by robp
Replied by robp on topic Making 31's fit
How would you sort the gearing? Would a sj410 transfer box help?
- ne-crock
17 Feb 2014 19:15 #104932
by ne-crock
Replied by ne-crock on topic Making 31's fit
a 410 box would help but to get any real benifit you'd want a 4.16 rocklbster or lower, depending if you want to drive it purely off road/ on road gearing for distances
you may get away with a 410box with it being an auto they seem to handle larger tyres easier or so i've read online...
- robp
17 Feb 2014 19:23 #104934
by robp
Are rock lobsters relatively easy to build? Looking at the instructions online they dont look too bad if i can get a 410 transfer box??
Time to create page: 0.095 seconds
