drivetrain noise advice needed
- Thank you received: 77
14 Feb 2014 17:01 #104489
by robs5230
standard jimny - for now
drivetrain noise advice needed was created by robs5230
need a few suggestions lads. i have a drivetrain noise at low speed . on setting off this presents as a groaning type of noise and disappears at about 15-20 mph. its possibly getting worse and now on drawing to a stop i'm getting a noise/vibration that feels like i'm running on octagonal tyres . this is only the last 6 feet or so drawing to a stop.
so...... i have considered the rear gearbox mount but i have checked and there is no movement at the back of the box. could this be a propshaft or something ??
many thanks in advance for any suggestions. rob
15 Feb 2014 09:20 #104558
by robs5230
Replied by robs5230 on topic drivetrain noise advice needed
any suggestions at all ??????????????? anything ?
15 Feb 2014 09:22 - 15 Feb 2014 09:25 #104559
by j999pre
Grey pick up Jimny
Replied by j999pre on topic drivetrain noise advice needed
UJ on a prop? My mini prop gave similar symptoms when it went. Transfer to gearbox i mean. Shouldn't be the front prop as it won't be spinning unless your manual hubs are in 4wd if fitted
Grey pick up Jimny
Last edit: 15 Feb 2014 09:25 by j999pre.
15 Feb 2014 10:02 #104561
by robs5230
thanks james, first dry opportunity i'll be under it , hopefully tomorrow. what exactly am i looking for ?
- GuardianAngel
15 Feb 2014 10:12 #104562
by GuardianAngel
Replied by GuardianAngel on topic drivetrain noise advice needed
You can try and rule out the rear prop by removing it and engaging the front hubs/4WD and then driving it in front wheel drive mode.
15 Feb 2014 10:30 #104563
by robs5230
other than a bent prop, are prop issues normally UJ related ? and can the UJ's be serviced / repaired ?
thanks
thanks
