Stuttering idle funny
  • Jimny87
14 Feb 2014 00:27 - 14 Feb 2014 00:36 #104454 by Jimny87
Stuttering idle funny was created by Jimny87
99 jimny 13bb stuttering problem
Hi just wondering if anyone might know what my problem is i have changed spark plugs / injectors and gave it a oil change with oil plus air filters but still stuttering when you accelarate lightly and gradually build speed up it is ok even if you punch it towards the end at high revs the car hammers but if you dont build up speed slowly and try to step on it from start to end its stutters and a huge power loss . If anyone can help me please i would be appreciated so much im now going to try changing the 2 spark leads and maybe try airflow sensor after cheers..
Last edit: 14 Feb 2014 00:36 by Jimny87.
14 Feb 2014 06:50 #104463 by robs5230
Replied by robs5230 on topic Stuttering idle funny
coil pack ?
standard jimny - for now
14 Feb 2014 06:54 #104465 by j999pre
Replied by j999pre on topic Stuttering idle funny
Cam sensor
Grey pick up Jimny
  • Jimny87
14 Feb 2014 10:54 #104469 by Jimny87
Replied by Jimny87 on topic Re:Stuttering idle funny
I will give it ago cheers
Sent from my GT-N7000 using Tapatalk
  • craigy123
16 Feb 2014 09:40 #104674 by craigy123
Replied by craigy123 on topic Re:Stuttering idle funny
I had this probelm with my last one and took off the feed pipe for the charcoal canister and it solved it. Worth a try as it appeared to be blocked. I've circled it in white
16 Feb 2014 10:07 #104675 by robs5230
Replied by robs5230 on topic Re:Stuttering idle funny
craigy123 wrote: I had this probelm with my last one and took off the feed pipe for the charcoal canister and it solved it. Worth a try as it appeared to be blocked. I've circled it in white
just out of interest, what effect will it have if the charcoal cannister is blocked ? is this a serviceable / replaceable part ? thanks
Time to create page: 0.091 seconds
