Service guide - diffs, transfer case, swivel hub.
  • Newell
12 Feb 2014 16:32 #104296 by Newell
Hello,
Just wondering if there is a comprehensive guide on here about; what to, and how often to, service parts on the Jimny.
How often you should change the engine, transfer, diff oils etc. How to do it, and what oil to use?
What else should be regularly serviced / improved in order to get a happier Jimny? e.g diff breathers?
This would be very useful information as everywhere I look I get a different answer.
Please ignore this if there is already a thing, (couldn't find it.)
  • GuardianAngel
13 Feb 2014 09:48 - 13 Feb 2014 09:56 #104348 by GuardianAngel
Replied by GuardianAngel on topic Service guide - diffs, transfer case, swivel hub.
There are a fair few guides. For oils, see: www.bigjimny.com/index.php/information/g...s-and-fluids-v15-283
To change the air filter, engine oil and filter and spark plugs, see:
Diff oils are easy enough. Undo the filler plug first before the drain plug just incase you can't undo the filler plug (rusted/rounded off). Then just top up until oil starts to come out of the filler hole. You might need an oil filler pump to make it a bit easier but not essential.
For the gear box, the same applies. Ensure you only put GL-4 oil in the gearbox and GL-5 in the diffs. GL-5 contains additives that could wreck some of the components in the gearbox.
As for diff breathers, there are plenty of threads on the subject if you Google "Jimny diff breathers".
For all other guides see:
www.bigjimny.com/index.php/information/qhow-toq-guides
www.bigjimny.com/index.php/information/general-information
Last edit: 13 Feb 2014 09:56 by GuardianAngel.
  • jonesyba420
13 Feb 2014 10:01 #104349 by jonesyba420
Time to create page: 0.073 seconds
